[ICEM] Hybrid Mesh on 2D airfoil
Old   July 29, 2014, 09:05
Smile Hybrid Mesh on 2D airfoil
Jrmy is on a distinguished road
Hi everybody
I'm a new user of ICEM CFD and I'm trying to do an hybrid mesh around an airfoil, but I have some problems. I had look at lots of other post on this subject in this forum but I didn't found the solution.
I want to have a quadra boundary layer and a triangular mesh around, like on the first picture attached to this message. I have something very closed but I have some issues with the trailing edge.
Being not a usual user of ICEM, maybe my mesh method is wrong. I did:
- Create a rectangular(*) farfield around my airfoil
- Create a surface (fluid) on this farfield, then segment this surface at the airfoil curve
- Delete the airfoil surface (so I have a airfoil shaped hole on my fluid surface)
- Build Topology
- Then Mesh with the following parameter:
Global Mesh Setup: All Tri, Patch Dependent
Part Mesh Setup: max size Farfield:1 , Fluid: prism and int wall option selected (not max size specified)
-Then curve mesh setup to specify the boundaries conditions that I want.
So I don't know how to have a better mesh near the traling edge. Thank you in advance for your response.
Jeremy
*If I do a circular farfiled, I am unable to segment the surface into a farfield surface and an airfoil surface and then to have an airfoil shaped hole in my fluid surface... I don't understand why It doesn't work with a circular surface...
Jrmy is offline   Reply With Quote
Old   August 12, 2014, 06:22
A little bit of help please
Regards,
Jeremy
Old   August 14, 2014, 15:08
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Try to add a curve at the trailing edge and mesh it using hexa
Far is offline   Reply With Quote
airfoil, airfoil2d, hybrid
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
[ICEM] How to do 2D hybrid mesh around hydrofoil jaber CFX 2 January 3, 2013 18:11
[ICEM] Need urgent help for hybrid mesh generation Pursuor ANSYS Meshing & Geometry 1 August 29, 2012 16:04
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
