[ICEM] ICEM CFD error when running in batch mode |
August 14, 2014, 14:45 |
Daniel B
Rep Power: 11 |
I am running ICEM CFD 14.5 using matlab. I create a ICEM CFD replay script using matlab with the command eval(['! icemcfd -batch -script ' MyDir '/GeoMeshScript.rpl']), which allows me to execute ICEMCFD. Everytime I use batch mode, I get this error message everytime: Usage split_grid node dim val [ dim:min,max ] [ m m1 m2 ... ] [ marked ] Usage split_grid node dim val [ dim:min,max ] [ m m1 m2 ... ] [ marked ] while executing "hexlib_interface__574 split_grid 21 25 GEOM.74 m GEOM GEOM_FLUID SOLID FLUID INLET OUTLET INT-PRESS-IN INT-PRESS-OUT CONTACT-REGION SYM-INLET SYM-OUTL..." ("eval" body line 1) invoked from within "eval $hexlib split_grid $args" (procedure "ic_hex_split_grid" line 15) invoked from within "ic_hex_split_grid 21 25 GEOM.74 m GEOM GEOM_FLUID SOLID FLUID INLET OUTLET INT-PRESS-IN INT-PRESS-OUT CONTACT-REGION SYM-INLET SYM-OUTLET SYM-FIN SYM-..." invoked from within "batch_interp eval ic_hex_split_grid $args" However, when I use interactive mode (basically change -batch to -interactive), so eval(['! icemcfd -interactive -script ' MyDir '/GeoMeshScript.rpl']), the replay script works perfectly fine and creates the desired mesh. I would prefer to run everything in batch instead of interactive mode because batch allows faster processing. Please someone help me figure out this issue Thank you |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 09:00 |
force to wait MATLAB for running parallel fluent in batch mode | a.latifi | Main CFD Forum | 1 | May 9, 2013 17:44 |
ICEM CFD use for ? | Vu Trinh Tuan | CFX | 14 | April 11, 2011 19:38 |
What do you CFD guys do during a long simulation running? | bearcat | Main CFD Forum | 5 | July 23, 2009 09:08 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
