August 20, 2014, 12:05 |
grid refinement for only 1 block
ruben
Rep Power: 11 |
Hey guys,
I'm currently working of some projects and was wondering if the grid with 1 block could be refined while keeping the same number of nodes in the other blocks. I've posted a pic online consiting of 3 blocks. I need the middle block to be refined at the left vertical edge since it is an inlet. Thus I would need more vertical nodes at the inlet. The other 2 blocks are solid and no refinement is required. Screenshot 2014-08-20 16.58.41.jpgHope yo guys have some suggestions. Cheers Ruben |
August 20, 2014, 18:10 |
yes you can do it. Go to blocking > pre-mesh parameters > Refinement.
For fluent you are allowed to have refinement of 2 to 1 and with the help of resolve refinement you can get mesh suitable for fluent. For non conformal mesh, you can choose any refinement factor. See also this post http://www.cfd-online.com/Forums/ans...s-problem.html |
August 21, 2014, 09:33 |
ruben
Rep Power: 11 |
cheers mate
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
matrix solver about block structured grid | young min, Sohn | Main CFD Forum | 1 | July 11, 2000 19:35 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
