[ICEM] Connecting blocks at interface
Old   August 21, 2014, 10:28
Default Connecting blocks at interface
ruben
ruben3031 is on a distinguished road
Hey guys,
I was wondering if blocks that were not previously linked could share the same interface in ICEM. I'm trying to mesh a tank which has a comp[licated geometry. I have tried meshing different parts of the tanks with different blocks and associated the blocks to the respective edges but it does not work in fluent. Any suggestions would be helpful. I've used a simpler example to showcase what I'm trying to do.
Cheers
Ruben
ruben3031 is offline   Reply With Quote
Old   August 21, 2014, 12:47
Sebastian Engel
bluebase will become famous soon enough
Hi Ruben,
I understood it that way, you want to set edge and copy those settings to all "parallel" edges right, for example all horizontal edges in your last screen?
I think there is an easy solution. Have a look on the attachted scheme. Create a single stripe of blocking with an additional block between each tank. Then, delete this block without the option for permanent deletion. Without deleting permanently those block are internally moved to the part VORFN. That way the link between the horizontal edges is preserved. Then you just need to move the vertices to thier designated location.
With regards,
Sebastian
bluebase is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
