October 20, 2014, 19:34 |
Gambit Meshing Tolerance Issues
PtolemaeusStroud
Hi!
I'm trying to mesh something at a wall where the cell size needs to be ~10^-9 meters I have scaled up my model in Gambit by a factor of 10^9 (scaling up any higher results in gambit crashing due to insufficient memory etc.) The geometry is just a 2D sketch of 2 concentric arcs with their end points connected. I have attached the generated mesh... I think that the funny kinks that can be seen are because of some sort of tolerance issue (in the middle, you can tell that a few nodes have the same y coordinate but different x coordinates). How can I increase the number of significant digits that Gambit can handle? Again - Scaling up higher is not an option, I have scaled it up as far as I can. You will have my undying gratitude if you help me fix this Thanks, Ptolemy PS: Can gridgen/pointwise deal with these low tolerances? |
October 21, 2014, 01:26 |
Maxime Perelli
Rep Power: 41 |
Gambit works without unit.
you will scale your model in the solver Can you describe with a sketch what you want to build and mesh (Are you talking about boundary layers?)
In memory of my friend Hervé: CFD engineer & freerider |
gambit, grids, meshing, small mesh, tolerance |
Display Modes | |
Edges numeration issues in Gambit | Fidippide | FLUENT | 2 | October 6, 2015 10:13 |
[ICEM] Geometry Tolerance and meshing | Mitpostdoc | ANSYS Meshing & Geometry | 4 | January 1, 2012 12:51 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
Creating geometry & meshing using Gambit | Ray | FLUENT | 3 | August 1, 2000 03:30 |
