[ANSYS Meshing] Recreate polar mesh from article |
September 14, 2014, 06:27 |
Rep Power: 11 |
Hi all!
I am trying to create a mesh based on an article and I got stuck. The original mesh was not made by Ansys. It is the cross-section of the solder paste during stencil printing process. The mesh's thickness is one element. I added the figures from the article. I also added the progress I have made yet. Is it even possible to make the same mesh? If not then how can I make inflation for the edges of the triangle part? I have already made inflation there, but it was rectangle and I would like triangles. Thanks for your support! partmesh_article.jpg fullmesh_article.jpg fullmesh_me.png partmesh_me.png |
September 14, 2014, 07:12 |
Amin
Rep Power: 14 |
Hi
In the shared edge between tri mesh and mapped mesh you must have an edge! For this you must use "form a new part" in ANSYS DESIGN MODELER! And about inflation! I think it's better for inflation that used mapped mesh! Tri mesh isn't sufficient for boundry layer mesh! |
September 17, 2014, 12:22 |
Rep Power: 11 |
Thanks!
Your help was very useful! |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
[ICEM] Mirror Mesh | Delete duplicate mesh | pythag0ra5 | ANSYS Meshing & Geometry | 6 | November 19, 2013 07:35 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
