[ICEM] ic_geo_surface_get_objects
Old   October 17, 2014, 11:00
Default ic_geo_surface_get_objects
François Grégoire
macfly is on a distinguished road
I can't get the geometry function ic_geo_surface_get_objects surface type [embedded_points] to work. I tried all the types (surface, curve, point, material, loop, density) and I always get the following error message (box8.00 is the name of a given surface):
Error: bad object type "'surface'" for surface "box8.00"
Moreover, I have no idea of what I'm supposed to do with [embedded_points]??
macfly is offline   Reply With Quote
Old   October 17, 2014, 16:34
Sebastian Engel
bluebase will become famous soon enough
Hi François,
i don't have an idea to what valid values are accepted. I think "embedded_points" is just the standard value for types.
There is a chance that you're looking for a function to get the boundary curves of a surface or boundary points of curves. If that's the case, have a look at ic_geo_boundary.
args: should be "ic_geo_boundary type ?names? ?outer? ?even_if_dormant? ?embedded?"
## Return what objects of lower dimensionality are the boundary of this one.
## Points are the boundary of curves and curves are the boundary of surfaces
## and loops. The list returned has a sublist foreach element in <em>names</em>
## such that {{c00 c01} {c10 c11} ...}, unless names is one elment, in which
## case the returned list goes as: "c00 c01".
## <i>names</i> may be one name, or a list of names
## <i>outer</i> may be 0 or 1, indicating what kind of boundaries
## <i>even_if_dormant</i> may be 0 or 1, indicating which additional boundaries
## <i>embedded</i> may be 0 or 1, indicating which additional boundaries
type should be the type of the parent entity
ic_geo_boundary surface s.c.wll.inl.1
Result: c.wll.inl c.p.wll.inl.1 c.wll.inl.2 c.p.wll.inlvrd.1
ic_geo_boundary curve c.wll.inl
Result: p.wll.inlvrd.1 p.wll.inl.1
with regards,
Sebastian
bluebase is offline   Reply With Quote
Old   October 17, 2014, 16:55
François Grégoire
Hi Sebastian,
Yes I'm looking for a function that will get some boundary coordinates of a given surface. I want to locate all surfaces and group them in different parts.
Thanks for ic_geo_boundary, I might use it eventually. I found ic_geo_get_srf_pos which gets the coordinates at a surface parameter, I think it's the simplest way to go.
Thanks for your input,
Regards
