Gambit Meshing Tolerance Issues
Old   October 20, 2014, 19:34
Smile Gambit Meshing Tolerance Issues
PtolemaeusStroud
Ptolemy is on a distinguished road
Hi!
I'm trying to mesh something at a wall where the cell size needs to be ~10^-9 meters
I have scaled up my model in Gambit by a factor of 10^9 (scaling up any higher results in gambit crashing due to insufficient memory etc.)
The geometry is just a 2D sketch of 2 concentric arcs with their end points connected.
I have attached the generated mesh... I think that the funny kinks that can be seen are because of some sort of tolerance issue (in the middle, you can tell that a few nodes have the same y coordinate but different x coordinates).
How can I increase the number of significant digits that Gambit can handle? Again - Scaling up higher is not an option, I have scaled it up as far as I can.
You will have my undying gratitude if you help me fix this
Thanks,
Ptolemy
PS: Can gridgen/pointwise deal with these low tolerances?
Ptolemy is offline   Reply With Quote
Old   October 21, 2014, 01:26
-mAx-'s Avatar
Maxime Perelli
Gambit works without unit.
you will scale your model in the solver
Can you describe with a sketch what you want to build and mesh (Are you talking about boundary layers?)
gambit, grids, meshing, small mesh, tolerance
Edges numeration issues in Gambit Fidippide FLUENT 2 October 6, 2015 10:13
[ICEM] Geometry Tolerance and meshing Mitpostdoc ANSYS Meshing & Geometry 4 January 1, 2012 12:51
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Creating geometry & meshing using Gambit Ray FLUENT 3 August 1, 2000 03:30
