[Other] Fluent Meshing, Scoped sizing - Mesh of thin plate
Old   March 30, 2018, 19:50
Default Fluent Meshing, Scoped sizing - Mesh of thin plate
RedoFromStart is on a distinguished road
Hello!
I'm trying to mesh rear wing of a racing car in Fluent and I'm having some problems understanding Scoped Sizing.
The plate's edges are rounded in order to obtain acceptable prisms quality.
Every sizing is scoped to label of an object. Rear wing is the object, label is an endplate. Geometry of the label is in the image "geometry.png".
When I choose curvature scoped sizing, whole plate is meshed with minimum specified size.
Face boundary option results in sizing shown in the image "face-boundary.png".
Face-face option gives the most meaningful results, show in the image "face-face.png".
However, there is an unwanted refinement near the region where the actual wing is.
Is there any way to remove influence of the wing on the refinement on the outside of the endplate?
RedoFromStart is offline   Reply With Quote
ansys meshing, meshing, plate, scoped sizing, thin plate
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 22:58
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
