Error when running in Batch Mode from Ansys Meshing
2 Attachment(s)
Hello colleagues,
I'm trying to run ICEM in batch mode from Ansys Meshing... I set the script files as in this video https://www.youtube.com/watch?v=ImnXZuFBnLE But when I try to update I get an error you can see in the picture I attached... I followed what was suggested in others threads about setting the path in environment variables, you can see that too in the other picture.... I'm still getting the error What do you think it's happening??? Best regards... Attachment 34915 Attachment 34916 |
Hi Gerardo,
It looks like you have saved your work in the directory: C:\Users\Gerardo Suarez\Documents\Simulaciones... Instead try saving it in a directory that does not have a space in it, e.g. C:\Simulations\ and see if that works, Good Luck Stu |
Best regards... |
