When meshing cannot link faces.
2 Attachment(s)
This a geometry of a water tube -Attachment 35542.Wen meshing,I want to link the two Attachment 35543,but the gambit prompts:ERROR:Cannot link faces face1,face6 duo to all loops of edges not being specified.That is why? Thank you !
you don't need to link the faces.
I would split both cylindesr at the extremities, then mesh the central volume prior to both cylinders |
This is a simple example ,I want to find the find reasons .The problem often display in the complex exmples when I was meshing.
1 Attachment(s)
I could reproduce your issue.
I fixed it, by splitting both surfaces. It is possible that gambit has a problem with a hole in a surface. Attachment 36163 |
