November 26, 2014, 21:17 |
When meshing cannot link faces.
wanghuo
Rep Power: 11 |
This a geometry of a water tube -geo.jpg.Wen meshing,I want to link the two face.jpg,but the gambit prompts:ERROR:Cannot link faces face1,face6 duo to all loops of edges not being specified.That is why? Thank you !
November 27, 2014, 00:59 |
Maxime Perelli
Rep Power: 41 |
you don't need to link the faces.
I would split both cylindesr at the extremities, then mesh the central volume prior to both cylinders
In memory of my friend Hervé: CFD engineer & freerider |
December 21, 2014, 08:00 |
wanghuo
Rep Power: 11 |
This is a simple example ,I want to find the find reasons .The problem often display in the complex exmples when I was meshing.
December 22, 2014, 06:00 |
Maxime Perelli
Rep Power: 41 |
I could reproduce your issue.
I fixed it, by splitting both surfaces. It is possible that gambit has a problem with a hole in a surface. Untitled.png
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
