[ICEM] Unable to confine tetra mesh to surfaces |
December 10, 2014, 03:51 |
Erik Solberg
Hi all.
Wondering if anyone can help with this. I am a new user, sorry for any stupidities. I am trying to develop a tetra mesh for the inlets and outlets of a counter-current heat exchanger. The problem is that ICEM computes the mesh in one end of the heat exchanger outside of the boundary surface. This happens whether I compute just one side or both at the same time. Weird thing is, one side is as it should be, the other is not. The surfaces are created by copying two curves from the end of the geometry by the transform geometry function, then creating a surface between the two new curves. The same for the other end of the heat exchanger. I do the exact same thing for both ends, but it still turns out wrong. Please refer to the attached picture in the link. https://www.dropbox.com/s/dbvevyehcb...bilde.PNG?dl=0 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 22:04 |
