December 10, 2014, 11:03 |
Improve Quality of Tetra Mesh
Rep Power: 11 |
I've created myself an unstructured mesh using tetra/mixed type. Now I'm trying to improve the quality of the mesh. I managed to increase the quality by about 0.1 by smoothing globally, however the quality is still pretty poor. Now I'm trying to find a way to improve further, but am struggling quite a bit. Could anyone suggest any ways I could go about doing this? Here are a couple photos of the mesh: Qualitymesh.jpgqualitymesh2.jpg Help would be much appreciated! |
December 10, 2014, 11:22 |
Rep Power: 11 |
Can you recommend how to go about refining it more? I have just improved by another 0.05 by increasing the density of mesh and smoothing again.
December 10, 2014, 11:23 |
Rep Power: 11 |
I am simulating heat transfer between hot water pipe (inner pipe) and cold water pipe (outer pipe)
December 11, 2014, 04:54 |
Rep Power: 11 |
From the tutorials I have access to none of them actually explain unstructured mesh refinement. I know I must use the edit mesh section but what tools to use I do not know. I have tried playing around with different things for hours but cannot find the correct way.
Please could someone help! |
December 12, 2014, 07:45 |
Rep Power: 11 |
Excuse my amateurness, but I have tried decreasing maximum size of all the parts and changing density but the quality seems to remain the same.
When you say 'just decrease the size', please could you explain what area to decrease? |
December 12, 2014, 08:52 |
Ghazlani M. Ali
Rep Power: 28 |
If you decrease the size and nothing change, it means the size element is still big. You should take a look at the scaling of your geometry. Use the ruler and measure the distance between two points. then you will decide based on that distance. When I say decrease the size, it's in the global mesh paramaters. make sure you click on apply and then go too compute mesh. this is explained in the tutorials. You should start by the tutorials.
December 12, 2014, 09:14 |
davide basso
Hi geod,
I think you're quality is not so bad at all. The problem with your mesh is that it is extremely coarse. another thing: if you are interested in thermal exchange between the tubes you'll need a prism layer of some sort on both the inner and the outer surface |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Other] Using mesquiteMotionSolver to improve mesh quality. | icaroaccordi | OpenFOAM Meshing & Mesh Conversion | 0 | August 6, 2014 08:59 |
[ICEM] mesh in-dependency and mesh quality control | sujay | ANSYS Meshing & Geometry | 0 | February 20, 2013 02:06 |
[ICEM] how to improve mesh quality around sharp edge? | foolboy007 | ANSYS Meshing & Geometry | 1 | January 23, 2013 11:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
