[GAMBIT] Link Face Meshes + Size Function
Old   April 14, 2015, 08:13
Default Link Face Meshes + Size Function
Nicola
sasizza is on a distinguished road
I am realizing the 3D mesh of a wind turbine blade (type NREL S809). Given the periodic nature of the geometry, it is possible to simulate only half domain, because the other half is a repetition of the first, halving the computation time and complexity of the simulation. To do this, I introduced the periodic boundary condition to the faces of the centerline of the volume, because the grid must be speculate between the two opposite faces. In Gambit you must use the command Link Face Meshes and then specifying the boundary condition “Perodic”.
In Fluent you must specify that the condition of periodicity is rotational and not translational.
To use the command Link Face Meshes, I divided the initial domain by a Vertical plane: I linked Base-plane 1 with Base-plane 2. When I impose the Size Function (Sources: blade faces; Attachment: Volume 6 and 7), I get the mesh of a single volume, while in the other volume, I can obtain only the meshed faces and not the volume. Moreover, I get the following error:
"Initialization failed; perturb boundary nodes and try again.
Initialization failed to mesh 3 nodes.
ERROR: TG_Mesh_Domain failed with error code 1.
ERROR: Tetrahedal meshing Has Failed volume for volume 7.
This is usually caused by problems in the face meshes.
Check the skewnesses meshes of your face and make sure the face mesh size are not too large in areas of small gaps
How can I solve this problem by applying simultaneously the Size Function and the command Link Face Meshes?
How can I get around this obstacle? If necessary, how could I change the geometry?
Thanks a lot.
PS: In the attached image, you find the Boundary conditions that I've imposed.
sasizza is offline   Reply With Quote
Old   April 14, 2015, 09:01
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Pretty sure your problem doesn't come from linked faces + SF combo.
For persuading you, try to delete all your BC and your linked faces, and re-try to mesh your volume with your SF.
If it failed, then your problem lies on your topology, and I guess you will have to split your domain for having more control on the mesh in the blade area
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
link face meshes, size function
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
