December 30, 2014, 02:17 |
the problem of copy volume
wanghuo
Rep Power: 11 |
In this picture 2.jpg the right volume was copied from the left volume .The face in the red red Circle of the left volume is an interior face(only one face),but in the right volume there is two face ,that is why?I want the face in the right volume is interior face like the left volume ,what can I do?Thank you very much!
January 5, 2015, 01:56 |
Maxime Perelli
Rep Power: 41 |
sounds like a connectivity problem.
I would connect All Faces
In memory of my friend Hervé: CFD engineer & freerider |
June 29, 2015, 03:46 |
wanghuo
Rep Power: 11 |
Dear Maxime!
Thank you very much!I'm sorry for the late reply because I was very busy! You said "conect All Faces"? What do you mean ?I have the same geomerys which are very complex .My purpose is that :I mesh one of them.If I can copy the geometry and the mesh together.I don't need to mesh the other geometrys! |
June 29, 2015, 04:24 |
Maxime Perelli
Rep Power: 41 |
if you copy volumes which are connected together, it will result of non-connected volumes .
So you have to reconnect the volumes check my example: on the left, 2 cylinders with split (connected > pink). I copy both cylinders which are placed on the right (the split is now blue, which means not connected) Untitled.png
June 29, 2015, 10:13 |
#5 | |
wanghuo
Rep Power: 11 |
Problem with negative volume in CFX | TallesC | CFX | 1 | February 4, 2013 16:26 |
[Other] Problem with negative volume in CFX | TallesC | ANSYS Meshing & Geometry | 3 | February 4, 2013 11:44 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Problem of negative volume.......Please help | nims | FLUENT | 3 | November 2, 2010 02:07 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
