How to import?:(
How to import the .msh file into ansys meshing.?
Any help would be appreciated.. |
In workbench right click on mesh and select import mesh file You can only import msh format! Any editing are not allowed… |
Thanks for the replay..
Actually I wanted to convert my mesh file which is in Binary to ASCII FORMAT.. Is there any other way to convert it?.. Or again I have to do it from the beginning to end. Thanks |
but maybe this threat help you to solve the problem: http://www.cfd-online.com/Forums/ans...ii-format.html |
I had gone through that threat earlier but that will help for the fresh start..
The problem is that I created mesh already without noticing the format in ICEM CFD and exported into .msh file..:(. Now I have been forced to change the format.. Does it possible? Thanks |
try these threat: http://www.cfd-online.com/Forums/ope...-openfoam.html http://www.cfd-online.com/Forums/ans...ii-format.html http://www.cfd-online.com/Forums/ope...-openfoam.html |
Thank you very much sir.:):):):):):):). You have solved my problem... I got it from the below link......
http://www.cfd-online.com/Forums/ans...ii-format.html... |
Good luck! |
Thank you for your kind response.:):)
How the connectivity between cells/nodes in the output ASCII file of fluent.? Is it one after the another or random?. In mesh file, cells/ nodes arranged in random:confused:. I needed this solution information for further coding.. Any help would be appreciated. Thanks Shivakumar |
