January 28, 2015, 13:28 |
Rotating the geometry
Ravinder Gill
Rep Power: 11 |
Is there a way to rotate a geometry by 90 degress in design modeler. I made a geometry with rotational axis as y axis, but later figured out that Fluent does axisymmetric modelling taking x axis as rotational axis only. So i need to rotate the geometry by a right angle.
January 29, 2015, 17:17 |
Rep Power: 14 |
Hi Gill11a,
You can rotate the body by "Body Transformation" Select all the bodies and choose you axis according to fluent and you should be fine Hope it helps Cheers KAPI |
January 30, 2015, 11:01 |
Ravinder Gill
Rep Power: 11 |
Thanks Kapi. Worked perfectly
Animation of rotating geometry | freddyk | STAR-CCM+ | 1 | December 20, 2012 07:29 |
Rotating geometry test case | zebra | Main CFD Forum | 0 | August 25, 2010 10:34 |
Rotating Geometry | Gearb0x | OpenFOAM Running, Solving & CFD | 0 | July 1, 2010 11:57 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
