[DesignModeler] Airfoil coordinate importing in DesignModeler |
March 28, 2015, 15:42 |
Osman
Rep Power: 12 |
I am trying to draw wing in ANSYS Design Modeler. I have imported the airfoil coordinate file in DM through 3-D curve. But the geometry is not changing to blue color after generating the curve and also I cannot modify the geometry. Where am I doing wrong? Can someone, please, help me on this? TIA |
March 29, 2015, 15:14 |
Did you use Concept > Surfaces from Edges?
http://www.cfd-online.com/Forums/att...-points-dm.jpg Best, Rahul |
March 31, 2015, 17:08 |
#3 | |
Osman
Rep Power: 12 |
But what is the problem with concept>3D curve option? Can you kindly explain it? I am mainly following a tutorial and it is done by that method but in my case, it didn't work. Regards, Osman |
March 31, 2015, 17:44 |
Osman,
3D curve as the name suggests, creates a 3D curve (a line body). You need to create a surface (surface body) from the 3D curve, if you trying to perform 2D simulations. You would have to extrude the surface (solid body), if you are trying to do 3D simulations. Complex 3D wing profiles can be modeled using the sweep/blend options. Best, Rahul |
Display Modes | |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 17:18 |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 17:17 |
Airfoil coordinate importing in Designmodeler | Aerofluid | FLUENT | 0 | March 27, 2015 03:19 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 10:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 10:26 |
