April 4, 2015, 23:32 |
Meshing a non flat tip blade
Rep Power: 11 |
Does anyone know how to mesh with turbogrid a non flat tip blade?, I mean a squealer tip blade? I tried to mesh it but when I give the clearance and run the mesh the tip looks like open and no tip geometry is showed.How do I must set up turbo grid to leave the tip geometry just as it is?
thanks for the information. |
September 4, 2017, 02:56 |
i man
Hi Luza
Have you find any souloutin? I have the same problem for a blade with squler tip. |
September 6, 2017, 03:31 |
#3 | |
Your geometry looks like this |
November 25, 2017, 08:59 |
Alex
Rep Power: 9 |
hello.do you know how to mesh the non-flat tip blade in turbine by icem? can you teach me about that?
tip-clearance, turbogrid |
[GAMBIT] 3D meshing of a tortuous blade | Persil | ANSYS Meshing & Geometry | 13 | January 15, 2014 04:58 |
[ICEM] High Stagger Rotor Blade Meshing | eromon84 | ANSYS Meshing & Geometry | 12 | August 14, 2013 06:40 |
[ICEM] Meshing a blade inside air volume | LittleBart | ANSYS Meshing & Geometry | 19 | October 10, 2012 09:20 |
[ANSYS Meshing] Meshing for flat plate immersed solid | hamed.majeed | ANSYS Meshing & Geometry | 0 | July 10, 2012 13:32 |
Meshing pitched blade turbine | Racheal | FLUENT | 0 | July 12, 2005 13:25 |
