[GAMBIT] Editing geometry in GAMBIT
Like Tree1Likes
  • 1 Post By -mAx-
Old   April 15, 2015, 19:02
Default Editing geometry in GAMBIT
Adnan
adnanakhtar is on a distinguished road
I am working on a problem and have to do a parametric study by varying one of the dimensions in the geometry.
The problem that I am facing is I only have the mesh file and dbs file of the mesh created by someone before me.
Is it possible for me to edit the geometry in GAMBIT? If anyone knows any other tool where I can edit the geometry using only the mesh file?
Adnan
adnanakhtar is offline   Reply With Quote
Old   April 16, 2015, 02:29
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
the *msh file won't help you.
the .jou file (from dbs) may help you, it transcripts every step from your procedures (from geometry to mesh)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 16, 2015, 10:03
Adnan
Thank you for the reply Max
So I guess I would have to use the dbs file. Delete the mesh. Change the geometry and remesh it to get my desired output.
Old   April 16, 2015, 16:18
Aja
aja1345 is on a distinguished road
Hi max,
Here, I have two questions.
How can to use .jou file until I understand every step from my procedures in Gambit?
How to create .jou file from .dbs file?
I am grateful for your help.
Best,
Amir
aja1345 is offline   Reply With Quote
Old   April 17, 2015, 02:05
-mAx-'s Avatar
Maxime Perelli
I think you have to recreate your modell from scratch.
You will see a *.jou file
Once you have it you can "replay" your steps by loading the journal file
aja1345 likes this.
Old   April 17, 2015, 10:57
Adnan
I had a question: I could create a new face in the geometry. However, when I go ahead with the meshing I receive a fatal error. The possible reason that I believe is the mesh for the new face has to be compatible with the existing mesh.
Would you be knowing a possible way I could resolve this? (Something like replicating the mesh structure in the new face similar to the previous meshing)
Thanks
Adnan
Old   April 20, 2015, 01:03
-mAx-'s Avatar
Maxime Perelli
what kind of error do you get?
how do you generate the mesh? from journal file, or from gui?
Display some pictures for a better understanding
Old   April 20, 2015, 11:05
Adnan
Thanks for the reply Max.
The error that I get is:
A fatal error has occurred. It is not possible for GAMBIT to continue from this point. Please report this error immediately to your local FLUENT office or distributor. Additional instructions and error messages may appear in the window in which you started this GAMBIT Session.
I am working on a previously meshed model. To edit my geometry I am using the meshed file (dbs file). I do have the jou. file in the same directory.
The model has several faces in 2D. You can consider a 2-D rectangle and that I want to add another rectangular face along one of its dimensions. I created my new face but when I tried to link the new face with the already meshed face, I got the error.
Is it not possible to edit the geometry to an already meshed geometry?
Thanks
Adnan
Old   April 20, 2015, 12:12
Adnan
The yellow lines are the new geometry added by me and the blue lines are the already existing geometry.
Old   April 21, 2015, 00:57
-mAx-'s Avatar
Maxime Perelli
yellow lines mean you only have edge, no surface.
Now you have to pick the 3 yellow lines, and the missing blue for generating new surface.
Old   April 21, 2015, 10:27
Adnan
I tried running a tutorial to see if I get a problem:
http://www.mne.psu.edu/cimbala/Learn..._flatplate.htm
Even for this case, when I mesh the face I am faced with the fatal error. Seems there is some problem with the GAMBIT installation or version (2.4.6) that I am using.
Old   April 22, 2015, 01:46
-mAx-'s Avatar
Maxime Perelli
try to create a rectangle (50x10) as surface and mesh it
face create width 50 height 10 xyplane rectangle
face mesh "face.1" map size 1
Geometry of Tank and Rushton Turbine in Gambit jawidnaik ANSYS Meshing & Geometry 1 February 4, 2015 07:28
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 26, 2012 23:54
What can I employ to create geometry besides Gambit? summer ANSYS Meshing & Geometry 2 February 11, 2011 14:50
Need support for GAMBIT geometry srbbd FLOW-3D 3 March 12, 2009 19:16
problem about Importing geometry in Gambit Hua Gu FLUENT 3 April 2, 2002 14:24
