destroy surface after build topology in ICEM
hi
I imported a complex closed surface geometry as parasolid(.x_t) format,but after building topology my surfaces destroy and gets a gap. is it important to build topology before start meshing? how can I fix this problem? I m not confident about my surfaces gaps,I use tolerance =0.01 |
build topology is important especially if you are going for patch dependent.
Try using a lower tolerance. As I remember rule of thumb - Tolerance = 1/10th of the smallest curve in the geometry |
