May 17, 2015, 10:12 |
Toolbars position
Hello, I would like to know if there's a way to lock or save the toolbars position. Thanks so much and have a sunny sunday!
May 17, 2015, 18:53 |
Hi Stabum,
I highly doubt that you can lock your Toolbar position! But it should come at the same position as you left. Cheers KAPI |
May 18, 2015, 00:55 |
Hello, Kali. What you say doesn't happen to me: every single time I start DM I reorder the toolbars the way I like and every single time I found them moved in a different (and horrible) order... What can I do???
-bye |
May 18, 2015, 01:08 |
I am not sure whats happening with your system.
Do you have dual screen? If you are moving from one screen size to other this might happen. If DM is opening in different screen in different instances then this might happen as well. KAPI |
May 18, 2015, 02:17 |
To tell the truth, yes, I have a dual monitor config. But the point is that I start DM, I do my things, I quit DM in order to start ANSYS mesh. After creating the mesh sometimes I come back to DM and... Boom! All the toolbars have changed their position! And all this within 5 minutes! With no resolution changes! Don't know what's going on ... Thanks anyway for your help!
May 18, 2015, 02:20 |
I can suggest one thing to try, Switch off / detach your secondary monitor and see if its still happening.
KAPI |
November 18, 2016, 15:14 |
Armando E. Kitto
Rep Power: 12 |
Hello Stabum, did you ever solve the problem with DM's toolbars?? I'm having the same problem and I don't use dual monitor. This problem is extremely annoying.
November 19, 2016, 19:10 |
Absolutely annoying! No solution so far, unfortunately, sorry...
June 28, 2022, 07:49 |
Armando E. Kitto
Rep Power: 12 |
It is now 2022 and this problem persists! Has anyone found a way to fix it? I've always had this problem, no matter how many monitors I use or what version of Windows I run. Ansys attention to detail sucks!
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
Force dependent on particle position | jranita | OpenFOAM Programming & Development | 1 | August 23, 2011 19:44 |
how to read in a position file | jiejie | OpenFOAM | 0 | May 23, 2011 04:38 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
