June 11, 2015, 05:19 |
Penetrating elements in extruded mesh
Umberto
Rep Power: 11 |
Dear all,
I was trying to extrude a 2D mesh which works fine when in two dimensions but, when I extrude it, shows quite a few penetrating elements which sprung up from nodes which apparently did not have any problem. I enclose the a picture of the 2D mesh and what I obtain once extruded I tried to look it up but didn't find any possible solution and most of the users having similar problems were using a hexa mesh, which I can't use as I'm implementing dynamic mesh. Thank you all in advance |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Fluent dynamic mesh 'remeshing' method for pyramid elements | DarrenC | FLUENT | 14 | December 11, 2015 04:58 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
