Blocking/meshing
3 Attachment(s)
Dear ICEM Users,
because of my rather modest knowledge of ICEM I'm stuck and do not know how to continue. In a picture below it can be seen a solid component(slice of exhaust turbine housing) upon which i added volume that represents fluid domain. Part is stationary and circumferentially periodic. 1.) I am wondering how to determine periodicity on the face edges of the casings (upper, bottom)? I do not have any reference rotation centerpoint i just have a periodic slice. 2.) When I approached blocking strategy it was unclear to me: when editing association > "edge - curve" what edge should I select? I am trying to devide domain around the blade/rib of a solid part. So should i take the inner edge of a rib/blade or outer. Any help would be appreciated and lifesaving. B.R. |
Mesh
I am a beginner in icem and i have a lot of doubts about meshing and regarding fluent.. How do you relate the mesh domain to flow conditions? I am working on the following flow conditions:
Geometry: airfoil naca 4412 Chord length= 1m C grid mesh velocity= 18 m/s ie mach of about 0.05 (in compressible flow) density=1.225 kg/m3 Model= spalart allamas Thank you for your answers in advance. |
