Script function to pick single Solid Body
Hi I need to select a solid body Design Modeler with script, in a design with multiples solids bodies. with the following command I select all the solid bodies but this is not what I need. I need to select one of all
ag.bodyPick; ag.gui.SelectAll(); |
Hi efirvida,
You have to first named select the body ( namsel1) you want to pick then use below code where you want to select that body Code:
ag.bodyPick; Cheers KAPI |
