[ICEM] Create geometry (iges or step file) from fluent mesh
Like Tree13Likes
  • 7 Post By sac
  • 1 Post By PSYMN
  • 4 Post By PSYMN
  • 1 Post By Jan Smedseng
Old   September 24, 2010, 05:05
Question Create geometry (iges or step file) from fluent mesh
muketa is on a distinguished road
Hi everybody,
having a Fluent mesh (file .msh) is it possible to open that mesh in ICEM to reconstruct the geometry and export that geometry in a IGES or STEP file? I've just tried the Mesh-->Facets command, but then I'm not able to export facetted geometry to IGES file...
Is there any method to recreate geometry (in a neutral format like iges so that i can read that geometry in a CAD software) from Fluent mesh?
I would appreciate any help. Thank you for your attention.
MUKETA
muketa is offline   Reply With Quote
Old   September 27, 2010, 05:33
Any suggestion??
Old   September 27, 2010, 08:16
sac
sac is on a distinguished road
In workbench take the part into FEModeler and set the cut angle to 0 then skin the geometry. This will create a surface for every facet.
Use the create parasolid command to create a parasolid from this and then use the sew tool to sew it together (you may need to play with the sewing tolerance to get this to work).
From this you can then export the parasolid.
Other programs - such as Rhino can do exactly the same type of operation. Also there is a macro for Mechanical APDL that does pretty much the same thing from IDAC's website.
Far, PSYMN, hityangsir and 4 others like this.
sac is offline   Reply With Quote
Old   October 5, 2010, 19:53
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I totally agree with SAC. Good post.
PSYMN is offline   Reply With Quote
Old   October 12, 2010, 10:43
arapha is on a distinguished road
hey,
I am trying to convert a .cgns file created in Pointwise to a .msh file for use in another in-house CFD code. Is there a way for me to create a .msh file directly in Pointwise, or a way to convert the exported .cgns file to a .msh file through FLuent or another software ?
Thanks !!
arapha is offline   Reply With Quote
Old   October 15, 2010, 12:40
Default ICEM CFD Output Tab.
PSYMN's Avatar
Simon Pereira
ICEM CFD can do it thru the output tab. You may also be able to do it in Fluent or Pointwise... You may also be able to find converters on line.
sodynamic likes this.
Old   July 26, 2013, 08:59
PSYMN's Avatar
Simon Pereira
I was privately asked for more details here, and specifically, if we could convert a mesh to IGES or STEP in ICEM CFD...
Converting mesh to facets is not the way. That is a good way to get towards an STL file (a faceted data format), but you could more easily export the mesh as STL. Instead, we use that conversion when we want to convert a mesh to a geometry so we can generate a new mesh from an old one. I like using the mesh editing tools to fix up STL files and then turn them back into STL files before I mesh them.
IGES and STEP need nurb/bspline surfaces. These are not faceted formats, instead, each surface has i and j data. It just so happens that our hexa blocking faces do have what is needed, so it is possible to convert via Edit => Structured Mesh to CAD faces. Then you would use File => Export Geometry...
I have seen users do this to create a coarse hexa blocking shrinkwrap around engine parts and then export them... But ICEM CFD is a meshing tool, it was not designed as a geometry prep tool so not much effort has been put into the File => Export Geometry and that step tends to be the weak link.
Other tools (Such as FEModeler or Rhino, as some have already mentioned on this thread) do a much better job. FEModeler is a free module in ANSYS Workbench, which comes free with ICEMCFD.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Old   July 26, 2013, 13:51
Thumbs up Export Geometry in ICEM CFD
Jan
Jan Smedseng is on a distinguished road
Hi.
Try this:
- Import the fluent mesh in ICEM CFD.
- Edit mesh >> Delete elements >> All volume elements
- Save the project
- File >> Export mesh >> Write STL file.
Now you have the STL file of the geometry.
You can import this STL file to the ANSYS DesignModeler (you have to change the postfix filter to |all files (*.*)|) or to ANSYS SpaceClaim.
You're now able to fix the geometry, add missing faces, merge faces...
You also have the possibility to export the geometry in different formats.
Regards,
Jan
Jan Smedseng
CFX Berlin Software GmbH
metmet likes this.
Jan Smedseng is offline   Reply With Quote
Old   August 4, 2015, 06:06
Exclamation export geometry from fluent
frety
jose_zola is on a distinguished road
hii all,
Please i need i little help here. i wrote a udf to change the porosity inside a volume in order to get some sort of a flow inside tubes. Now after i interpret the function a need to export the new volume( with the new porosity distribution) to be able to print it 3d. please any ideas?
jose_zola is offline   Reply With Quote
Old   August 4, 2015, 10:56
Default Separating grid
Jan
Hi.
Thats not so hard. In ANSYS Fluent you can define a region by an Isovolume. Just select "Adapt >> Isovalue".
In the next step, you can separate the mesh by this new region. Just select "Mesh >> Separate >> Cell"
Now you have two possibilities. You can write a case file and import it to ICEM CFD or you can switch to fluent meshing an export an msh file there.
The rest is as described in the post above.
Regards,
Jan
Old   August 5, 2015, 06:38
Thumbs up
  #11
frety
thank you so much for your reply. you help me a lot. one more question what value should i use for the iso value(velocity, pressure.. ) i tried to limit the velocity but it seems that isnt working
fluent mesh, geometry, iges
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
convert FLUENT mesh file to CFX mesh file?? frederic felten FLUENT 5 December 6, 1999 10:32
