[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ?
Old   August 19, 2015, 18:12
Default Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ?
Jackie Stan
RPjack is on a distinguished road
This is a cohesive heat transfer analysis involve several solid and one fluid region. Initial mesh was generated in workbench mesh. However mesh in the fluid region cause iteration problems. (See https://www.dropbox.com/s/5ga2bnep39tqkmh/1mesh-cross-section.PNG?dl=0)
So I imported mesh generated from workbench mesh into Fluent meshing (Tgrid), Used auto mesh to generate the mesh for the whole part. Mesh in the fluid seems better, But mesh in the solid is bad
(See https://www.dropbox.com/s/r52q0u7iwpinv48/4.png?dl=0)
Can I keep the sweep mesh in the solid and only remesh the fluid region in Tgrid? Or is there a way to generate sweep solid mesh in Tgrid?
The solid parts and fluid share the same interface (identical surface mesh) for the purpose of cohesive heat transfer analysis.
Thanks for helping!
RPjack is offline   Reply With Quote
Old   August 19, 2015, 18:17
Default How to generate good mesh for Fluent cohesive heat transfer analysis
Jackie Stan
Advice on how to generate good mesh involve several solid body (rectangular shape solid except heat sink) and a fluid region for cohesive heat transfer analysis is greatly appreciated!
Old   August 27, 2015, 09:33
Far
Sijal
did you solve your problem ?
meshing combine, tgrid, workbench mesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[ANSYS Meshing] Solid inside Fluid - Multizone meshing supercolli ANSYS Meshing & Geometry 2 July 9, 2014 13:20
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
