Mesh Over Cylinder
Dear all,
Can anyone help me in unstructured meshing over cylinder. I have seen the tutorial where we make one in 2D and then extrude it in 3D. But I am trying to mesh in 3D geometry directly. But in the z direction (i.e. normal to cylinder cross-sectional surface) I want only one cell thickness. Is there any way, apart from blocking. Please help. with regards, Ashwani |
3 Attachment(s)
Hi, Why do you use the structure mesh? You can block the computational domain. It is easy. I do it in Gambit. Please see the attached file. Best, Aja |
Thanks for your reply.
I need to validate our unstructured code on non-hexagonal cell. By using one cell direction, I am able to compute 2D cases using 3D meshes with relatively less number of cells. I needed it in ICEM for this is available meshing tools for us. So, if it can be done in icem - how to fix number of layer in one direction. |
