August 20, 2015, 06:14 |
Mesh Over Cylinder
Ashwani
Rep Power: 12 |
Dear all,
Can anyone help me in unstructured meshing over cylinder. I have seen the tutorial where we make one in 2D and then extrude it in 3D. But I am trying to mesh in 3D geometry directly. But in the z direction (i.e. normal to cylinder cross-sectional surface) I want only one cell thickness. Is there any way, apart from blocking. Please help. with regards, Ashwani |
August 21, 2015, 09:39 |
#2 | |
Aja
Rep Power: 14 |
Hi, Why do you use the structure mesh? You can block the computational domain. It is easy. I do it in Gambit. Please see the attached file. Best, Aja |
August 21, 2015, 10:24 |
Ashwani
Rep Power: 12 |
Thanks for your reply.
I need to validate our unstructured code on non-hexagonal cell. By using one cell direction, I am able to compute 2D cases using 3D meshes with relatively less number of cells. I needed it in ICEM for this is available meshing tools for us. So, if it can be done in icem - how to fix number of layer in one direction. |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
ICEM block mesh with a ball in a cylinder tube | Li | CFX | 6 | August 11, 2008 05:44 |
mesh problem for cylinder | akr | FLUENT | 1 | January 29, 2007 23:43 |
