Meshing problem
Hello all, I am facing a problem in ICEM. I have a concentric cylinder geometry .1m inner dia from which air is flowing and outer 1m in which solid is there i have named part as inlet,outlet,outer body, and defined inner circle as pipe because it has some conductivity and i am working on heat transfer when created a structured o grid and imported in fluent the pipe part is now coming but when i am creating a unstructured mesh pipe part is coming in fluent, I have to use structure mesh only and i tried different way of creating it but for structured it is now showing. Anyone will tell me what can i do or this is the bug in icem?
How to solve: Export your structured mesh to CFX format if you have that software. Because CFX can handle structured meshes( I suggest CFX because you have access to ANSYS package I am guessing). Constraints: You cannot use fluent for structured meshes. Fluent = Unstructured CFX = Both structured and unstructured I hope this makes things clear. |
I am converting structure mesh into unstructured mesh in icem in the tree and exporting it to fluent but still i didnt get any change it wont take and wont create interface. |
Like Shereez suggested, use your original mesh in CFX. You should not have much problem operating CFX if you are familiar with Fluent.
Note: Version number change in ANSYS is much faster than windows ;) |
So any solution for me why it is not showing part when i do structure and convert it??
http://www.cfd-online.com/Forums/ans...em-fluent.html |
