August 27, 2015, 23:31 |
Blocking notch tip
Wang Zhe
Rep Power: 11 |
Dear all,
I'm blocking and meshing a domain depicted in the figure below. It is a one-quarter view of a semi-elliptical notch tip in a pipeline section. In Workbench geometry I have separated the whole geometry into several blocks. Therefore, I am going to mesh the notch tip using ICEM through multizone method and the rest using Workbench mesh. However, I have been stucked on it for one week. I have two questions regarding this issue. 1) how to block such a geometry; and 2) I have created a mesh using ICEM (not very good one) but fail to import into the workbench mesh. I have seen other's mesh, see the fourth pic, and I really want to get a comparable mesh myself. I've attached pictures of my current blocking and mesh. I'm sure that this is an easy task but I just can't figure it out. Any information would be greatly appreciated. Thank you. Regards, Wang Zhe |
August 28, 2015, 00:29 |
Wang Zhe
Rep Power: 11 |
Hi, I may find a way to figure it out. Instead of generate a mesh on the one-quarter geometry, one-half is much more easier! Attached is my blocking.
However, I still have no clue on how to mesh the one-quarter geo. Suggestions and comments are more than welcome. Thank you. |
August 28, 2015, 02:45 |
Wang Zhe
Rep Power: 11 |
Another two pics regarding blocking and meshing.
However, when I try to export to workbench, it shows error and ICEM window prompt out again. Any ideals? Thanks. |
August 28, 2015, 06:12 |
Wang Zhe
Rep Power: 11 |
Hi, I have uploaded my geometry and mesh files. I really need your help to figure out why such mesh cannot import into the ANSYS static structure. Thanks.
[ICEM] make tip gap surface, ICEM | Jonathan | ANSYS Meshing & Geometry | 2 | July 3, 2014 11:06 |
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh | yona | ANSYS Meshing & Geometry | 8 | January 21, 2014 10:06 |
[ANSYS Meshing] Blade tip blocking | Bollonga | ANSYS Meshing & Geometry | 108 | November 6, 2013 13:59 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Blocking strategy for 1mm tip clearance | mr_stoked | ANSYS Meshing & Geometry | 2 | September 21, 2010 15:00 |
