[ANSYS Meshing] meshing 2d VAWT
Like Tree3Likes
  • 1 Post By amin.z
  • 1 Post By amin.z
  • 1 Post By amin.z
Old   August 31, 2015, 23:22
Default meshing 2d VAWT
abuabdellah
abuabdellah.albatal is an unknown quantity at this point
i am sorry, but i am new
and i do not know if this is the right place to post that or not
i am working on 2d VAWT i used the workbench meshing but i think it doesn't go right because of the mesh ...
can i mesh like this in workbench meshing ?
if not where i can do mesh like that in ansys products ?
thanks in advance ...
best regards ...
abuabdellah.albatal is offline   Reply With Quote
Old   September 2, 2015, 05:31
Default ideas guys!!!!
abuabdellah
ideas guys!!!!
Old   September 3, 2015, 03:38
amin.z's Avatar
Amin
amin.z is on a distinguished road
yeah, Ansys meshing is able to generate a mesh similar to these photos,
you need to divide your domain and use inflation
amin.z is offline   Reply With Quote
Old   September 3, 2015, 08:52
abuabdellah
i do it, but the element not triangular !!
Old   September 3, 2015, 09:07
amin.z's Avatar
Amin
Select the body, then right click and select method, eventually use triangle or patch conforming as method
Old   September 3, 2015, 09:43
abuabdellah
sorry.. but where i should right click ?
Old   September 3, 2015, 11:28
amin.z's Avatar
Amin
in the graphic window select the body which you want apply triangle mesh on it the right click+inset+method
Old   September 3, 2015, 12:20
abuabdellah
thanks alot !!!
i found it ....
but one question si there is a big influence on the solution from quadlateral and triangles ?
Old   September 3, 2015, 13:17
amin.z's Avatar
Amin
it depends on the accurate that you prefer, if it's so important for you, maybe it's better to use a structure mesh, if not use triangle,
if you generate a high quality triangle mesh, I guess it will be satisfactory...
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
2D vawt simulation meshing and fluent error daysley FLUENT 5 April 15, 2014 19:51
[GAMBIT] VAWT 3D meshing in Gambit nana ANSYS Meshing & Geometry 1 January 16, 2013 10:12
[ANSYS Meshing] Meshing a 3d VAWT Rudysa2 ANSYS Meshing & Geometry 2 February 28, 2011 22:58
