HEXA block structure smoothing
4 Attachment(s)
I'm trying to smooth a blocking in a Hexa mesh (Pre-Mesh Smooth) using the Multiblock method. The idea is that vertices of the blocking are moved to get a smoothed block structure. I tried to illustrate the problem using a simple mesh of a box, see attachments for a general blocking/mesh and the desired blocking/mesh results. However, I can't get the vertices moving using the Multiblock smoother. Anyone experience with this kind of problem and some directions how to handle the problem? Settings for Face Options, Vertices Options etc.? |
As i know, it does not move the vertices. However it tries to make them orthogonal at their current location.
Ok, then I might have misunderstood the idea of multiblock meshing... Two new questions arise:
