October 9, 2015, 10:04 |
Very small geometry
Gustavo
Rep Power: 10 |
I modeled a structured surface in the top of my model (standard ahmed body). I´m having problems to generate the mesh. (See then model in attach). I already have the results of the simulation without this structured surface. Now I would like to run another simulation with the same parameters but now with this structurated surface in the top of my model and compare the results. This triangular structure has 100 micrometers height. Anyone has any hint? Regards |
October 9, 2015, 10:12 |
sluzzer
Rep Power: 11 |
What is the problem in meshing?
October 9, 2015, 10:31 |
Gustavo
Rep Power: 10 |
So, sometimes appears these error message "A software execution error occurred inside the mesher. The process suffered an unhandled exception or ran out of usable memory"
And sometimes this one "One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities". "One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology." I tried to create a body of influence in this area of the structured surface (triangular) but the error persist... |
October 9, 2015, 10:45 |
sluzzer
Rep Power: 11 |
Set method to 'patch independent method' and set the max element size which is 1/10th of minimum gap..
However it may need more memory.. Use Icem cfd.. 2 options in icem cfd 1. Mesh a single slot and use translation periodicity 2. Mesh one surface with surface blocking and extruded mesh if the slots are through |
October 9, 2015, 10:47 |
Rep Power: 18 |
I don't think that this is good idea to mesh such a small geometrical entities. Maybe you should use different approach.
October 9, 2015, 10:48 |
sluzzer
Rep Power: 11 |
Please explain Antanas
Gustavo
Rep Power: 10 |
Thank you shivasluzz I will try that...
Antanas... what different approach would you recommend? |
October 9, 2015, 10:53 |
sluzzer
Rep Power: 11 |
I couldn't understand the geometry fully.. Is that a projection or blind slots or through slots?
October 9, 2015, 10:55 |
#9 |
sluzzer
Rep Power: 11 |
Oh is it like a fins projecting outside?
October 9, 2015, 11:01 |
#10 |
Gustavo
Rep Power: 10 |
It´s like a fins projected outside...
please see detailed view in attach. |
October 9, 2015, 11:05 |
#11 |
sluzzer
Rep Power: 11 |
Oh.. Ok..Going to do cfd analysis? I mean you want to mesh this geometry as it is or you want to mesh the surroundings?
October 9, 2015, 11:08 |
#12 |
Gustavo
Rep Power: 10 |
I did a farfield.. than used boolean (subtract).. So I´m meshing the surroundings...
October 9, 2015, 11:21 |
#13 |
sluzzer
Rep Power: 11 |
So in the surrounding, those areas will come as a trapezoids... Better to isolate that region then reduce it to single trapezoid, then do blocking, then translate blocking, then merge the blockings through merge topology and convert to mesh..
If you are not experienced with structured meshing, then do similar thing.. 1. Isolate 2. Reduce to single 3. Mesh it 4. Translational periodicity for full mesh 5. Merge all meshes |
October 9, 2015, 11:26 |
#14 |
Gustavo
Rep Power: 10 |
Sorry, but I´m not familiar with this.. I´m using Ansys Meshing... I don´t have ICEM. It´s possible to do with Ansys Meshing?
What do you mkean with isolate? Blocking? Translate Blocking? I think I´ve never seen this in Ansys Meshing panel.... |
October 9, 2015, 11:34 |
#15 |
sluzzer
Rep Power: 11 |
Oh.. All those terms are related with icem cfd structured meshing...
I forgot is there any periodicity or symmetry option in ansys meshing or not.. If there then reduce your model, mesh it and use the periodicity or symmetry option.. (this will save time, memory and effect than meshing the full geometry at once) Even if not there, reduce the model and mesh and I'm cfd software you can replicate your reduced model to full model by transform mesh options |
October 9, 2015, 11:45 |
#16 |
Gustavo
Rep Power: 10 |
But I have already reduced to half... because there is just one symmetry plane...
August 26, 2018, 08:35 |
#17 |
Hamed
Rep Power: 9 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 09:25 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
[ICEM] Geometry too large! | brunorgs | ANSYS Meshing & Geometry | 10 | May 20, 2010 21:20 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 15, 2000 23:39 |
