[ANSYS Meshing] Mesh similar to gambit - building
Old   November 6, 2015, 07:45
Default Mesh similar to gambit - building
Fabio Malizia
Fabio88 is on a distinguished road
Dear all,
I am trying to make a mesh around a building.
I was using gambit so far and it works quite well.
I am trying to do the same mesh in Ansys Meshing but I am having some problems. In detail I get a non conformal mesh (faces are not matching along the contact face between two different volumes, see picture attached).
These are the operations I made with Design modeller and Ansys meshing.
DM:
Create box (my building)
Freeze
Enclosure
Boolean/subtract -> Now I have only one volume (named air)
Create different planes
Slice -> Obtained different volumes slicing the air volume with the planes
AM
I have tried to use contact region and size function on edges, but withous success. Indeed all the times I mesh, the resulting is non conformal.
How can I make the cells in the contact region be the same?
Maybe I am just trying to mesh as I will be in gambit but it is not really possible. or maybe I am making some silly mistakes.
Thank you for any help you can provide me.
Fabio
Fabio88 is offline   Reply With Quote
Old   November 6, 2015, 10:18
Fabio Malizia
I found that I can mesh the edges of the two coincident faces the same then I do not have any problem anymore with non conformal mesh.
However, it is there an easiest way to define the contact between these coincident faces?
I tried to use contact inside DM but then AM forgets about it.
Thanks for any help you can provide me.
Fabio
Old   November 9, 2015, 11:11
Fabio Malizia
I found that in DM, under parts, selecting the parts you have, right mouse button and selecting form new part, when we switch to AM we do not have anymore the problem with multiple faces!
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
