Home > Forums > ANSYS Meshing & Geometry
[ICEM] Build Topology STL surface issue
Old   December 1, 2015, 10:48
Default Build Topology STL surface issue
Joseph Nettesheim
nettesheim2 is on a distinguished road
I am relatively new to ICEM and am wondering if anyone can figure out why I cannot successfully build the topology of an STL file I import into ICEM CFD.
Within ICEM CFD, I do the following:
File -> Import Geometry -> Faceted -> STL
Geometry (tab) -> Repair Geometry -> Build Diagnostic Topology
using a Tolerance of 0.001
I apply this, and get the errors: 'Couldn't find curve point to move'
And "curve _______ edge not in surface _____"
Followed by the program getting hung up.
The STL file, even compressed, is too large to upload. I create the STL file in Mathematica. The code used to generate the 3-D shape is:
r=(1-Cos[2 theta]^4)^20 * (1-Sin[phi]^4)^20;
g=ParametricPlot3D[{r*Sin[theta]Cos[phi],r*Sin[theta]Sin[phi],r*Cos[theta]},{theta,0,2Pi},{phi,0,2Pi},PlotRange->{{-1,1},{-1,1},{-1,1}},PlotPoints->50];
SetDirectory[NotebookDirectory[]]
Export["fourlobe.stl",g]
I have used this approach before for other 3d shapes successfully.
Thanks,
Joe
nettesheim2 is offline   Reply With Quote
build topology, stl file, tolerance
Thread Tools
Trackbacks are On
STL surface ignored -snappyhexmesh Ananthakrishnan OpenFOAM Meshing & Mesh Conversion 4 July 9, 2015 05:31
Structured or unstructured meshing of a STL file (surface) Milad06 Pointwise & Gridgen 4 April 25, 2013 11:55
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
Issue with STL file in Flow3D Rajiv Kothari Main CFD Forum 1 July 24, 2006 12:53
