December 5, 2015, 19:38 |
Export ANSYS Mesh Setting
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I have a bunch of artery geometries which I want to mesh them using same mesh topology and then model them by ANSYS CFX. What I want to do is to: 1- Mesh one of the geometries and find the best meshing settings 2- Export the mesh settings to use for the next geometries 3- For the next geometries import the saved setting such that ANSYS starts to mesh it automatically. Then I don't need to do the meshing setting for all geometries from the beginning. Please let me know if this is doable. Thanks AshtonJ |
December 6, 2015, 17:47 |
Rep Power: 14 |
Hiya!
It is doable. You need to write .JS file for your mesh and call it when you want to run mesh from Run Macro>Tools You can then change your local sizing or inflation or even global mesh settings from the file Cheers KAPI |
December 8, 2015, 20:19 |
wanghuo
Rep Power: 11 |
Dear kapi!
How to write the .JS file?Thank you very much! |
December 9, 2015, 19:33 |
Rep Power: 14 |
Hi guys!
what i mean is, you cant export mesh settings but you can create a .js file and put all your setting and run the .js file where you want and how you want. To make a .js file, you need some knowledge of javascript, you can start with Help section and see how they tell you to create js file and use it. Any specific function you are after once you are done with learning, you can ask again or search the thread for answers Hope it helps Cheers KAPI |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Rotating Mesh and export Mesh | ahmadreza | ANSYS Meshing & Geometry | 10 | July 12, 2015 04:17 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
[ANSYS Meshing] Export Gambit mesh into something Ansys workbench meshing can read? | amad11 | ANSYS Meshing & Geometry | 1 | February 21, 2012 12:26 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 02:19 |
