[ICEM] Material Points are not in the volume catagory |
December 6, 2015, 13:55 |
Rep Power: 10 |
Hello all. I'm trying to mesh fuelcell which has 9 different bodies inside. While I'm importing geometry,I always select "import material points".However there is problem about that,3 of 9 material points goes to mixed/unknown category in the boundary conditions.They should be in volumes part otherwise fluent do not recognize these 3 parts as volume.How can I overcome this?
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
UDF: Using Data Points for material characteristics? | Jim87 | Fluent UDF and Scheme Programming | 0 | July 31, 2013 10:12 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
