[ANSYS Meshing] Overlapping Named Selection error though every named selection differs from each othe |
December 7, 2015, 13:25 |
Onur
Rep Power: 10 |
I am working on 3D heat exchanger flow fluid analysis. on photo below I have uploaded is relevant to overlapping name selection that I have never made same named selection in same geometry face/edge/vertex How could it possibly to happen even if I could not give any same named selection? Moreover all tubes have been picked up together and all tubes is intersection to outer region that I make design Thanks in Advance https://imageshack.com/i/paX0frrbp |
December 10, 2015, 21:49 |
Rep Power: 14 |
seems you have used same face or edges in two different named selection.
Check your named selection one by one and see which two named selection highlights this face/edge! remove it form one or other named selection!! sorted! cheers KAPI |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Overlapping Named Selection error though every named selection differs from each othe | Onurozcan | Main CFD Forum | 0 | December 6, 2015 16:12 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
