[ANSYS Meshing] Inflation mesh with relate to Growth Rate |
December 12, 2015, 20:22 |
Onur
Rep Power: 10 |
I am working on 3d heat exchanger analysis. I have given a value in total thickness in inflation mesh( with relate to y+) As shown below, waste gas fluid domain mesh ( inflation) in vertical is rough/fluctant rather than the around tubes( that is diameter of tubes) https://imageshack.com/i/paGgN1X1p What should I do? Growth rate/number of boundary layer should be decreased ? or something else? As I have given a value in total thickness with relate to y+ or boundary layer number, If I change growth rate/boundary layer , I am going to change total thickness that will be good if you give a valuable information. Thanks, Kind Regards, |
December 20, 2015, 21:20 |
Rep Power: 13 |
Show your inflation layer bodies and faces selection as well, then someone might be able to tell why you are not getting the inflation layers at these faces.
and give more general info as well regarding the mesh. |
Display Modes | |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[ANSYS Meshing] Failed mesh following inflation preview | Nicki_p | ANSYS Meshing & Geometry | 2 | January 8, 2017 09:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
controlling unstructured mesh growth | tucker | FLUENT | 3 | November 2, 2005 14:27 |
