December 18, 2015, 11:51 |
Different surfaces
ami
Rep Power: 10 |
I am a new member in this forum and I hope someone can help me,please, to resolve the problem. I created a geometry using points and curves, I want to create two different surfaces on ICEM. I have already created one surface from curves. There is one curve which is suppoted to be communal for the both surfaces, when I select the curves whose one is communal for both surfaces to create the second surface, ICEM select the whole first surface and not only the curve which it is shared by both surfaces. I need your help please. Thank you in advance |
Extra shadow and duplicate surfaces | highhopes | FLUENT | 1 | February 16, 2023 01:41 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
[ANSYS Meshing] Surfaces with high curvature | mohammad | ANSYS Meshing & Geometry | 9 | November 24, 2014 01:02 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Faceted surfaces in ICEM | Chriss | Main CFD Forum | 1 | May 6, 2008 15:18 |
