[DesignModeler] Create sketch from line
Old   December 20, 2012, 04:20
Default Create sketch from line
P. L.
johnybelt is on a distinguished road
Hi there,
Is there a way of automatically create a sketch in the DM from a line body.? Generally is it possible to do the exact opposite thing of "Sketches from Lines"
or "Sketches from Surfaces"?
johnybelt is offline   Reply With Quote
Old   December 20, 2012, 05:33
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Create a new plane where you want the sketch, right click the plane and Insert>Sketch Projection
jrunsten is offline   Reply With Quote
Old   December 20, 2012, 05:53
P. L.
Thanks a lot !
Old   March 13, 2017, 12:06
amir ghasemi
amir_hiwa is on a distinguished road
actually i don't find any straightforward method for this, but there is a trick. by using spline or multi line in ''sketching'' copy the curve and now u have your sketch
amir_hiwa is offline   Reply With Quote
body, line, sketch
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
[Gmsh] Layers in a curved surface Artex85 OpenFOAM Meshing & Mesh Conversion 1 December 18, 2011 08:51
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 21:24
