February 13, 2016, 07:31 |
Help ICEM cfd
haze
Rep Power: 10 |
Dear all,
I need help. When I try to make a surface from curves in ICEM cfd it shows surface not visible error. What can I do to solve this. Thanks in advance |
February 14, 2016, 20:55 |
Raj Narayan.G
February 14, 2016, 22:53 |
haze
Rep Power: 10 |
The geometry was imported (iges)
February 15, 2016, 07:15 |
Sebastian Engel
Rep Power: 20 |
I guess, this is not an error. Do the following: in the model tree, activate surfaces. The message just tells you the imported geometry is not visible due to your visibility settings on geometry (points,curve,surfaces).
February 15, 2016, 08:25 |
haze
Rep Power: 10 |
Thanks a lot blue base...
I don't know if this is the right place to ask this. I always get an error in fluent 15 after it had completed some iterations. It states the f1 process could not be started an the program doesn't respond. It won't even save |
icem, not visble, surface |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing Solidworks part into ICEM CFD | MetalSupremacist | FLUENT | 0 | October 8, 2010 17:46 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
