Some parts are showing transparent
When I started meshing in ansys workbench meshing all parts r visible as shaded exterior I did some mesh trials and then I saw that some of my parts in Assembly are turned into transparent. I checked view option where shaded exterior is highlighted. How to make that particular part to normal view. Help me |
İf you are working on fluid rather than solid it will appear.That is not problem but if you want to change it you''ll see in left side ''TREE'' and there is a named ''connections'' you can button one click and there will be opened in page below ,change it enable ''no'' rather than yes |
Hi thank you for your suggestions. The problem solved. By default the transparency level was set to very low so after changing that all the parts are visible.
