[DesignModeler] Nozzle Fitted Box with surface for inlet |
February 22, 2016, 06:53 |
Deependra
Rep Power: 10 |
Hallo Guys,
I have simple query, if somebody could answer that, it would be great. Actually I want to create a box in which a round pipe is attached and inlet of pipe should be possible to select on surface. I want to create this geometry for jet flow simulation and keeping pipe inside box. Please let me know, if some body has idea to do this. Please have a look at geometry in figure that I want to create. Thanks Deependra Last edited by Deependra; February 23, 2016 at 06:33. |
February 23, 2016, 06:59 |
Rep Power: 13 |
what do you mean keeping pipe inside box?
also you can just select different faces by clicking on them, so what exactly is your question? |
February 23, 2016, 07:07 |
Deependra
Rep Power: 10 |
Thanks hwet for your reply,
I want a pipe attached to box surface as u can see in figure. My problem is that if I use Add material operation I dont get imprinted face of pipe on box surface and if I use cut material then it cuts surface of imprinted pipe on box surface. I want to do jet flow simulation, my jet is pipe and to define inlet, I want to have pipe of surface as imprinted on box surface. I know it is simple problem but not really getting right operaton Please let me know, if you can tell more about it. Regards |
February 24, 2016, 17:44 |
Rep Power: 13 |
i am guessing the pipe is going to be the jet inlet?
Then you can subtract the pipe form the geometry by using boolean. since you are not simulating the jet itself from the inside you dont need to have a mesh there. the jet should simply start from the face you will get from the boolean operation. |
February 25, 2016, 04:52 |
#5 | |
Deependra
Rep Power: 10 |
Please let me know, if you can tell that how can I get common interface for box and pipe surface. Thanks for your answers. Regards |
[snappyHexMesh] snappyHexMesh will not delete bounding box | AlexanderMath | OpenFOAM Meshing & Mesh Conversion | 2 | November 8, 2016 02:11 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
