[ANSYS Meshing] Creating several components with indivdual meshes to solve fluent problem |
February 26, 2016, 05:29 |
Rep Power: 10 |
in order to improve the mesh quality for a fluent compressible flow simulation i was thinking about slicing up a body into several bodies and meshing each component individually, and reconnecting them via mesh interfaces. By doing this i could improve the mesh quality and micro-manage the mesh generation. I wanted to know if this is generally a good idea and what kind of precautions i would have to take and what else i would have to take care of. I am happy for any pointers or help. |
March 1, 2016, 05:30 |
#2 | |
Onur Özcan
Rep Power: 12 |
Could you please share with us your bodies? you know that you could simply assemble your geometry that has a variety type of bodies.Then you could see that geometry you have defined have been shown like one-by-one parts in DesignModeller. As for Ansys-Meshing, you could hide any parts (or supress) and make it mesh you would like to After some mesh operations complete, you could see in mesh metric what it is like for example skewness must be max 0.95, orthogonal quality min is approximately 0.1 .Then you have to look at element quality in mesh-metric.Maybe some locations you will see would be not enough then mesh relevant locations Kind Regards, |
March 8, 2016, 04:01 |
Rep Power: 10 |
hi oozcan,
thank you very much for your reply. The reason for me using the separate body approach is reducing skewness and improving orth. quality. This way i get quality meshes on each distinct body. My post was targeting the question if this approach is in general sensible. |
fluent, meshing 2d, multi body |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 08:20 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
how to solve evaporation problem in fluent | dkb_bg | Main CFD Forum | 2 | September 30, 2011 00:06 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
