[DesignModeler] Creating surfaces from points data |
February 28, 2016, 12:52 |
abcd efgh ijkl
Rep Power: 10 |
Hello, I am trying to do CFD analysis of NACA-2424 airfoil. I have coordinate data in the format.. #Group #Point x y z. I am using only 1 group for points on both upper and lower portion of airfoil. When I import coordinates data in Ansys Design Modeler, it shows discrete points. Is there a way to create curves/lines between points to complete airfoil?
February 28, 2016, 17:38 |
Rep Power: 13 |
Yes Ali,
you need to create script for that. Create your points, lines and curves thru scripting. Read about it in Help section on Ansys. If you dont understand then I will send you a sample of geometry not airfoil tho! Cheers KAPI |
March 3, 2016, 21:28 |
abcd efgh ijkl
Rep Power: 10 |
Hi, Kappi!
I have trying to create airfoil from the coordinates. I go to Concept->3D Curve in Ansys Desing Modeler and browse to the file containing coordinates. The coordinates are in txt file and the coordinates are arranged as below: #NACA 2424 Airfoil Coordinates #Group #Point #X #Y #Z 1 1 0.000000 0.000000 0 1 2 0.008550 0.038920 0 1 3 0.020120 0.054490 0 1 4 0.043800 0.075520 0 1 5 0.068200 0.090520 0 1 6 0.093000 0.102150 0 1 7 0.143330 0.118880 0 1 8 0.194270 0.129590 0 1 9 0.245550 0.135930 0 1 10 0.297000 0.138740 0 1 11 0.400000 0.136060 0 1 12 0.501180 0.125320 0 1 13 0.602030 0.109030 0 1 14 0.702440 0.088240 0 1 15 0.802330 0.063520 0 1 16 0.901610 0.035020 0 1 17 0.950980 0.019300 0 1 18 1.000000 0.000000 0 1 19 0.016150 -0.036460 0 1 20 0.029880 -0.049650 0 1 21 0.056200 -0.066140 0 1 22 0.081800 -0.076920 0 1 23 0.107000 -0.084650 0 1 24 0.156670 -0.094500 0 1 25 0.205730 -0.099590 0 1 26 0.254450 -0.101550 0 1 27 0.303000 -0.101240 0 1 28 0.400000 -0.096060 0 1 29 0.498820 -0.086440 0 1 30 0.597970 -0.073470 0 1 31 0.697560 -0.058240 0 1 32 0.797670 -0.041300 0 1 33 0.898390 -0.022800 0 1 34 0.949020 -0.012920 0 1 35 1.000000 0.000000 0 I have tried a number of times and everytime error message pops up "Error reading Coordiantes file." What mistake I am making? Thank you |
March 4, 2016, 00:34 |
Rep Power: 13 |
Hi Ali,
this is how co-ordinates are written in script Code:
function planeSketchesOnly1 (p) { p.Plane = agb.GetActivePlane(); p.Origin = p.Plane.GetOrigin(); p.XAxis = p.Plane.GetXAxis(); p.YAxis = p.Plane.GetYAxis(); p.Sk1 = p.Plane.NewSketch(); p.Sk1.Name ="Sketch1"; with (p.Sk1) { p.Ln1= Line(0.33127,0.10845,0.37098,0.10845); p.Cr3= ArcCtrEdge(0.36984,0.11073,0.37098,0.10845,0.37212,0.10959); } with (p.Plane) { } p.Plane.EvalDimCons(); return p; } var ps1 = planeSketchesOnly1 (new Object()); agb.Regen(); save this code in .js file and go to DM and File>Run Script You will see how it is creating line and small curve. Use similar way to write your script JS file and run it. Hope it helps Cheers KAPI |
surface from points |
Display Modes | |
Data at nodes/grid points of cells | sagnikmazumdar | OpenFOAM | 3 | April 25, 2023 11:40 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
XYZ (ASCII format) data points into GAMBIT | Neil | FLUENT | 1 | August 7, 2007 10:24 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
Points on surfaces in a rotating mesh | Martin | FLUENT | 0 | August 22, 2000 14:36 |
