GreenJayPackers |
March 21, 2016 21:17 |
Question regarding Y Plus (y+)
I am using an SST k-w model to simulate airflow through an awkwardly shaped duct. I was told that if 95%+ of the y+ is below 5, then it is sufficiently accurate.
However, I found that if I simply add 'cells across gaps' and 'inflation layers', I get mostly sufficient y+ values (before I added more cells and layers, about 70% was below 5. After, it is about 98-99%). This seems like an inaccurate method to get the majority y+ values<5, but I am not sure.
So basically, can I assume my simulation is accurate if 98-99% of it is y+<5? Even if all I did was add cells and layers?
