[GAMBIT]-how to connect two pipes
Like Tree1Likes
  • 1 Post By -mAx-
Old   March 23, 2016, 00:47
Question [GAMBIT]-how to connect two pipes
Muffazal
Muffazal is on a distinguished road
Dear all,
How to connect two pipes each of diameter 6"(L shape). Length of horizontal pipe is 58.7m and that of vertical pipe is 19.5m. Please if some one can help me with step to step procedure. Thanks in advance
Regards,
Muffazal
Muffazal is offline   Reply With Quote
Old   March 23, 2016, 01:11
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
please post a sketch of what you want to do
Far likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 23, 2016, 07:32
Muffazal
Max thanks for your prompt reply.....
I have resolved the problem and completed with my geometry.....
but now I am facing problems in meshing...
Plz if you can help me to mesh the same...
I will be sharing my file with you soon.
Thanks and regards
Muffazal
Calculate Friction factor K for "Pipe connect to a Pipe body" susuint Main CFD Forum 1 January 15, 2016 08:56
Connect two pipes with different space stap CFDDmitry Main CFD Forum 0 May 19, 2011 07:24
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 04:17
cylindrical pipes Ben Siemens 4 June 16, 2004 11:25
